Hehe, thanks!
After a gluing incident the array looks worse than ever. Some of the PZT(?) has fallen off and some of the remaining have been covered in tin...
However, using a laptop and a microphone I was able to measure the main beam to somewhere between 14 and 28 degrees wide (and sort of 140 degs high), but this was in our living-room so I had to use a low strength signal to reduce the scattered reflections off our furniture...
It is also important to note that I have no idea what the specs of the mic are. It's the mic of a simple Logitech headset and it probably isn't ideal for picking up the 15kHz signal I use...
I spaced the elements a wavelength apart (11mm), if possible I'll try to put them next to each other and see if I get a different result. It is also important to test the characteristics of a single element.
I've ordered a bunch of new elements to make further tests with more than three (and I may even use better tools to cut them, free-hand with the dremel isn't the best way to go about it).
I've been thinking about turning the brass(?)-side outwards (way thicker than 1/4-wl, but what the heck) and adding an inch or so of plaster to the side with the element, any thought on this? Do you have any hints-from-the-pro, GLB?
