Hi guys,
had my Burton side scan for a while now but never got to use it due to various reasons. Finally got out the weekend with a group of divers from Cardiff and went for a play.
having never used it before it took me a while to get to grips with the Sensitivity-Would it be best to run it at full sensitivity while scanning and sort out the scatter afterwards?
Made a serious &%^&^&up when i played the images back-for some reason I had only managed to record about 4 runs-This really naffed me of as had been out for a while. I think i pressed exit after keying in record rather than ENT!!!!! The only thing i can come up with.
Is there any way of checking that the image is recording once set? It made it really bad as I had an amazing image come up on the screen of a wreck and its holds and deck rails so clearly visable it was like looking at a photo-and it did not record--AHHHH.
I did get an image of the wreck recoreded before that but from a distance.
Great images recorded of rocks etc and have spotted what looks like a man made image on one of the rock formations next to the wreck so worth a dive to check out-could be part of the wreck that came of when she sank.
If scanning in 50m of water for a lost wreck what would be the ideal amount of cable to run out for the side scan? should she be as close to the bottom as can manage without the risk of foul up or is it best to have herat about half way point say about 25 m? I have no idea so any help from you guys will be fantastic.
I loved the time out looking and can,t wait to get out there again. When i figure out a way to upload my images i will try and post them here.
One other question-I have read that working in the greayscale is ok but that bottom black will give better results when used to the machine-Is this correct and if so do i need to change any other setting apart from the greyline up to 60% as i am not that good at using her yet but can quite easily set it to the above and can find my way around the head unit pretty well-the Lowrance download has really helped here.
Oh one last question is there any good books worth buying that may be able to help a complete novice like me to get more out of the machine or does anyone have anything they could e mail me. The book that comes with the machine is a bit basic and does not answer all the questions??
All help appreciated.
I am sure i will think of more questions to ask
Feed me guys
Cheers
jeff
Feed me guys
Cheers
jeff
