I have a few questions about the structure of an LSS-scan sonar and Lowrance HDS-8-transducer 83/200:
1. Are these devices can be powered from a battery? If yes, what I should be the volume - how many Ah?
2. Which solution is better fitting:
2A. Two transducer - one by one
2B. Two transducer side by side
3 What should be the minimum distance between the Transducer 83/200 (HDS-
and StructureScan Transducer
3A
3B
4 As the difference in the level should be between 83/200 Transducer (HDS-
and StructureScan Transducer -? Do I have to mount them on the same level or better for one was a few inches above and one below?
4A
4B
5. Seeking a proven way to mount the transducer both portable installation
6. Does anyone have any videos or photos on a portable transducer mounting HDS-8 and a LSS-1
Thank you very much in advance for your help!
3A
3B
4A
4B
