Surf pi with PIC help
  • Surf pi with PIC help
    HEllo
    i made this metal detector and i wanted to modify it
    i want it give 5v or 0v output
    no speaker
    any ideas?
    -Put your modification so understands you .
    -Do not ask anyone to modify to you.
    j.
      i was thinking about using analog comparator
      what do you think?
        Jap
        i want the output to be
        5v with metal
        0v with no metal
        how can i do that?!
          Hi eessoo
          Did you mean any metal?.... or descrimination.
          best time
          j.
            any metal
            instead of the sound from the speaker
            i want it to give 5v
              Do you want not to use speaker?,,And use LED Instead speaker
              best time
              j.
                yes i don't want the speakers
                i want 5volt so that i could connect it to the micro-controller
                  Hi eessoo
                  you CAN use speaker or LED ONLY its out stage. what about micro-controller ?
                  best time
                  j.
                    i want to take the output and send it to micro controller
                    but it must be above 2.5volt for the micro controller to sense it
                    i wanna change the output of the metal detector to 5volt
                      What is the function OF micro-controller ?
                      What do?
                      What need of it?
                      best time
                      j.
                        ROBOT
                        mine detecting robot
                        if there is a mine the robot should stop
                        that's why i want 5v signal from the metal detector
                        if the micro controller sense the 5v it will stop the motors and do some other stuff
                          robot-----
                          What size robot that will carry all?(pcb MD+ coil+ pcb main+,,,,)
                          Usually with a robot carries light like Sensors,,,,in our case things like Pinpointer .
                          In any case you need a new design project.
                          best time
                          j.
                            it's a big car
                            with high torque motors
                            it can hold all this stuff
                            it will hold 4 metal detectors
                              What do you do from the effect of the big car metal on 4 coil?
                              best time
                              j
