Originally posted by maikl
You are correct have a few 7660 in stock because there used on the Minipulse3, Q1 using TIP127 old stock from the original radio spares so no problem there but wondering did it have a heat sink? , still need to make the coil.
The only thing that ive strayed from original Barrcuda is 6,800mfd capacitor ive used 4,700mfd because of size, but if i feel the need will order one up, its just im trying to use old stock.
All R/C components were checked before installing so apart from a couple of things to keep a eye on should be a result.
Been following Alexismex layout files with a fine tooth pic, You mention fast coil, by any chance do you know what wire and coil configuration was used in the original 8" Barracuda, its wound on a 7" form but was it laminated sold copper, tin plated copper wire as coiltek did and still do, Litz wire, if so how many strands, be nice if I could make original, to be honest I dont know if it was jumble wound or anything.
A fast very simple fast coil would be the famous spiderweb coil, but would rather stick to original if possible.
Many thanks
