Cure for reversed battery and burnt parts.
  • Cure for reversed battery and burnt parts.
    I posted the below in another thread and then I thought it might get more exposure in this section, so here it is.
    Hi folks.
    The CURE to connecting a battery backwards is a bridge rectifier. (4 pin device or 4 diodes)
    Connect the battery to the AC inputs, disregarding polarity. The + and - outputs go to the original battery inputs.
    If you doubt this, draw it out and try both directions of the battery. If connected properly in the circuit, + out will be + voltage. It's all black magic.
    Sorry about this post being so late buy I just saw it.
    Good luck,
    Old Fox
    The bridge rectifier is a good idea, but you will get two voltage drops with it.
    A single diode will only give you one voltage drop.
      >6666
      1.4 volts. That's only one more alkaline. And not even 1/2 of another LiFePo.
      If someone has a detector without a polarized battery pack connector, then it would be a good idea. It will take a bit of installation ingenuity though.
      I never worry about battery pack size. I size it to what I need after the circuit is working on the bench.
