VLF with direct sampling
  • VLF with direct sampling
    Hi
    I am writing here first time so hello everyone . I'm from Poland so sorry for my english.
    I'm thinking of building a metal detector with direct sampling. Signal from rx coli will be sampled direct with precision fast ADC and all calculation will be done in processor.
    All circuits that I know use synchronous rectifiers to split signal on two components - magnetic and electric (or more if used more freqency ex. Whites V3i). My previous prototype also use synchronous rectifiers (link for prototype's movie: http://youtu.be/5OF-lGxCKCo )
    Do you know someone VLF metal detector with the direct tx signal sampling?
    B.R.
    pepe
    The Minelab X-Terras use direct sampling, and the White's 6T uses quadrature direct sampling. I don't know of any canned projects that do.
      I would like to use the sampling frequency of about 1MHz - 2MHz. The transmitter would be built from the H-bridge in order to achieve high current in the coil transmission with acceptable power consumption from the battery (return energy to the capacitor).
      I built this type of detector but he only used the 12-bit ADC - range was woeful.
      Now I plan to use the 24bit converter.
      I wish I had found someone who has already tried to do so.
      Minelab probably will not tell both details.
      B. R.
      pepe
        The direct sampling (24 bit ADC) Minelab Xterra circuit is available here:
        http://phazitron.narod.ru/repair/xterra.htm.
          Thanks for Xterra circuit It has very simply rx and tx and audio stage - all build from audio codec. It is very smart
            with direct sampling are projects:
            Tango - http://www.md4u.ru/viewforum.php?f=2...2c9e120358ca70
            Quazar - http://www.md4u.ru/viewforum.php?f=9...c91ffbd841e0ef
            good luck
              Fine projects . In my design I plan use much more powerfull CPU (arm - stm32f4) an faster ADC. For display I will use second cpu (one box with metal detector and one with display to have better balance).
              B.R.
              pepe
