Back to the top...
I have very limited experience in PCB layout. I understand that guard rings are often used around the input pins on JFET (& I guess now CMOS) input opamps. But I don't understand how they affect leakage current.
It would seem to me that guard rings would only provide some level of AC isolation, and then mostly if you ground the guard ring. Also, it would seem that you would want to guard ring the whole trace(s) that connects to the pin, and not just the pin itself. And, with the low frequencies dealt with in detector-land, I would even question the usefulness of all this.
Can someone give a detailed explanation of what guard rings do? Do you use a common guard ring around both the + & - inputs? Do you ground the guard ring?
- Carl
- Carl
