IDX Pro VDI connection points for other detector models
  • IDX Pro VDI connection points for other detector models
    hello
    some days before i tested the idx pro vdi at my igsl musketeer
    something that i want to do since a long time
    results are really nice it makes fun to swing that thing
    the next what come to my mind was to use this as backup modul
    for tesoro cibola and compadre so why not try
    i think at compadre i could find the right points but cibola is an other thing
    the next will be other models
    my old gc1023
    so if anyone has tested vdi at other machines why not collect some connection points here
    write your detector model
    name the connection points
    X / name of ic and place on pcb / pin number
    y / name of ic and place on pcb / pin number
    Hi bernte_one,
    let's start to contribute to this thread with an entry for the Deeptech Vista Mini (German Edition):
    Connections:
    Vcc (+12 V): thick brown cable
    Gnd: thick blue cable
    X: IC=AD8664 (looking at the component side it's the topmost on the left, just left of those four 47n capacitors), Pin 14
    Y: same IC, Pin 8
    Characteristics (value unit is V):
    Mode X Y
    No Object, Disc = Min 4.1 - 4.3 4.3 - 4.5
    No Object, Disc = Max 4.1 - 4.3 4.7 - 4.8
    .50 BMG shell (distance ~ 1 cm) ~ 3.0 ~ 2.0
    Range 0.4 - 5.0* 0.4 - 5.0*
    Range for smaller objects up to BMG 3.0 - 4.5 2.5 - 5.0
    Voltage change for non-ferrous objects drops drops
    Voltage change for ferrous objects drops rises
    *May exceed 5.0 if object is very large and distance very small
    Greetings and happy hunting!
    Sargon
      Hello Sargon,
      many thanks for your support here and at the other constructions sides.
      We are only at beginning now, and i hope that you can share your wisdom here too.
      kind regards bernd
        Hello bernte_one,
        Can you explain something about connections between ISGL and VDI you write above?
        I am interested to add one VDI to my IGSL Musketeer, with a little display that will show only two big digit. My idea is to use the Nokia display of a 5110 mobile phone.
