PICKINI = PI detector, PIC based, KINE = motion, PICKINI= typical garment in the natural habitat of this MD, the beach.
This is a very simple, straightforward, easy to build PI detector. I am in no way an analog electronics specialist, so I shamelessly copied the front end of the blind squirrel detector and hooked it up to a simple Microchip controller. Since software is more my speciality, the shortcomings of the front-end electronics are somewhat compensated by the signal processing software + audio feedback.
There is only 1 control: a 4K7 potmeter for sensitivity combined with the power switch.
So far, we built 6 units, and all perform equally well. Air tests show about the sensitivity one can expect from a 20 cm diameter coil: about 25 cm for my gold wedding ring. 20 - 30 cm for euro coins. All depends on the quality/size of the coil.
That is why I spent some more time on field tests instead of simple air tests. I normally search with an XP GoldMaxx Power which is like most IBdetectors an excellent detector on fields, but is close to worthless on the beach. With the Pickini detector I searched fields that I had gone over with with the XP GMp and still recovered small items at greater depth.
On the beach, it never gets boring, although a lot of the finds are trash.
You can find all the data + PCB + software here:
http://users.telenet.be/willaert/MD/..._en/intro.html
Have fun,
- Bernard
Have fun,
- Bernard
