PICKINI - an easy to build PI detector
  • #31
    Originally posted by F117 View Post
    Just curious if anyone has reproduced the PICKINI design so far ?
    Some feedback would be greatly appreciated.
    I have built 6 detectors so far, all with 20cm coils and they all work fine...
    regards,
    - Bernard
    I have etched two more boards for v2,so far.
    I am drilling them.
    Still waiting for some components to arrive.
    I have received the Picks,and will load the new hex soon.
    John
    • #32
      I just can not build .... I have flu, 40 degree fever :-( I'm bored ..... but I can not really move ......
      greetings from the snowy Germany, marc
      • #33
        Hope you get well soon, -- same thing here in Belgium - flue, colds, snow, etc...one of the worst winters since the announcements of the global warming.....
        get well soon ! All the best,
        - Bernard
        • #34
          Still waiting components, they must be on a slow boat from China!
          Also I noticed there is no pinpoint as per v1?
          Can this be added as seen in v1 schematic?
          John
          • #35
            John
            I've checked for you ... and they're in the 9th container from the left. 2nd up, and 5th along.
Name:	The Great Immensity.jpg
            • #36
              John
              The pinpoint push button was omitted - all it did was reduce the sensitivity to almost minimum.
              I never experienced this as useful in the field.
              Best regards,
              - Bernard
              • #37
                The pinpoint function is still there, but is not brought out to a connector. It can be connected to TP7 on the board, if you really want to try this out.
                I also experienced when ordering samples from Microchip, that it took about a month before they arrived.
                • #38
                  "I've checked for you ... and they're in the 9th container from the left. 2nd up, and 5th along. "
                  It may as well be!
                  F117, the micros have arrived and I have loaded the hex.
                  Just some components are still AWAL.
                  Thanks for reply about pin point.
                  • #39
                    F117,
                    Bernard,I have noticed on your website a new v2 is posted with a 8mhz xtal.
                    The eagle board and schematic links dont work for me.
                    Is the software the same?
                    I hope I can modify the v2 boards Ive made to suit the xtal.
                    • #40
                      F117,
                      Please do an update of my webpage (F5) or direct link: http://users.telenet.be/willaert/MD/...ectronics.html
                      The V2 layout of the board has the possibility to stuff the crystal + 2 capacitors as oscillator.
                      These only need to be stuffed for V1 - with 20MHz oscillator and PIC16F616.
                      with the PIC16F1825, the crystal and capacitors don't need to be stuffed. It runs on its internal oscillator = 8 MHz, multiplied by 4 internally.
                      So, the board layout V2 can be used for both versions. The main redesign of the layout was to have the potmeter/switch on board.
                      I would like to do some tests to see if the PIC16F1825 runs more stable with an external 8MHz Xtal, multiplied by 4 internally, compared to the internal RC oscillator.
                      Bottom line: V2 works with the software you can download and without the Xtal.
                      Best regards,
                      - Bernard
                      • #41
                        Thanks Bernard.
                        Still cannot download eagle board3 or eagle schematic.
                        It sends me to a site Telnet "page not found"
                        John
                        • #42
                          You're right, John.
                          I will fix the links as soon as I get home tonight.
                          It is still morning here and I can't do it from work.
                          Best regards,
                          - Bernard
                          • #43
                            Website is in sync again:
                            http://users.telenet.be/willaert/MD/..._en/intro.html
                            • #44
                              Thank you my friend Bernard..I was getting confused with your "all in one " board.
                              Thanks for confirming that.
                              I have now received just about all components..so I can carry on and "get stuffing" my boards...LOL
                              John
                              • #45
                                hi bernard,
                                my board is finished :-) looks good, i think.....can you tell me, which wire gauge you use for your coils?
                                regards, marc
