Great work gurdal. Thanks.
PICKINI - an easy to build PI detector
Bonjour Nick,
Nice work on the PCB
Instead of putting energy in porting the code to another PIC flavour:
If you want the 16F1824 within a couple of days: order them with Farnell - France:
http://fr.farnell.com/microchip/pic1...44?Ntt=16f1824
cost: 1.57€ for 1 piece.
Success,
- Bernard
hi bernte one nice to read you .your posts on another threads help me a lot to finish my project (particularly for barracuda ,then tgsl ,idx pro etc...)
could you tell me how to do or could i post you directly by mail ?
i have made a lot of sprintlayout board retraced of some metal detector modified like idx or tgsl etc...(some resistor are not very well placed ) if you are interested tell it.
thanks
johnandles
Did you use the "contact" method to make the pcb for this project ?
is there a link to the instructions for useing contact ?
We spoke about this briefly on a thread somewhere, but when I run the contact
through the laser printer it crinkles and shrinks with the heat.
The basic info I have is you first print the PCB on paper to see where the pcb is being printed
then cut out a piece of contact and stick it over the pcb printing
then run the paper through the printer again to print on the contact.
hi 6666
for my projects i use a scotch tape (not for pupil ) but for windows or furniture (i use paper not the sticker of course )it cost 2€ for 10 meter so you can do a lot of pcb.simply print your layout on the shiny side of the paper (perhaps you'll have to do some test) .or you can try with a photo paper for ink printer but not the glossy paper ,i used matt paper.
have a sunny day because in france it's again and again rainy!!!!!!
The contact has to be unpeeled from its backing (hope that doesn't sound condescending) then stuck over the previous print.
Use a credit card to Iron out any wrinkles, (this is important)
Then re run through the laser again on high resolution.
Then Iron on as usual.
It worked for me.
I have previous pictures posted here and It is a working detector..(on the bench, at this stage).
The info should be on an 'Industructables' web site.
Hope this helps
Cheers
John
Hi F117!
Look carefully at the detector scheme and see that the transistor BS170 is shown as NPN transistor. Datasheet Fairtsild Semiconductor says BS170 is N-Channel Enhancement ModeField Effect transistor. What is true NPN or N-channel.Is it possible in the circuit diagram be considered NPN transistor BC170?
The transistor on the PCB is a really a BS170 MOSFET. I used the symbol of an NPN transistor in Eagle, just to get the PCB layout right with the 3 legs aligned in a row instead of triangular. I know you can create your own components and I did for the combination of potmeter/switch.
This transistor is just a level translator, should work also with an NPN transistor.
Best regards,
- Bernard
