Originally posted by Carl-NC
View Post
This one seems quite broad:
http://patft.uspto.gov/netacgi/nph-Parser?Sect2=PTO1&Sect2=HITOFF&p=1&u=/netahtml/PTO/search-bool.html&r=1&f=G&l=50&d=PALL&RefSrch=yes&Query=PN/6636044
The claims defining the invention are as follows:
1. In a metal detector apparatus including a transmit coil or a transmit/receive coil adapted to transmit magnetic field pulses when operating with electrical current flowing through the coil, transmit and receive timing control circuitry controlling the electrical current flowing through the coil, power supplies, and receive signal circuitry and receive signal processing circuitry coupled to the coil, a method comprising the steps of: transmitting magnetic pulses via the coil; and accumulating a receive signal received by the coil in the processing circuit coupled to the coil; wherein said receive signal is weighted more heavily after a transmit pulse transition and less heavily after a longer period following the transmit pulse transition.
2. A metal detector apparatus of a type including a transmit coil or a transmit/receive coil adapted to transmit magnetic field pulses when operating with electrical current flowing through the coil, transmit and receive timing control circuitry controlling the electrical current flowing through the coil, power supply means, and receive signal circuitry and receive signal processing circuitry coupled to the coil, wherein the coil is arranged to transmit magnetic pulses, and the processing circuitry is adapted to accumulate a receive signal which is weighted more heavily soon after a transmit pulse transition and less after longer following the transmit pulse transition.
Also do you have any idea why they made this two claims and not one? They seem to have just re-worded the last sentence and added the word method. Some legal difference perhaps?
Midas
