help with baracuda please
  • help with baracuda please
    hi all, just built the baracuda kit from silverdog, have a question, where does the external pot for delay go?, there are only 2 holes on the board near the trimmer but they are shorted by a track?
    any help would be greatly appreciated.
    remove the trimmer
    and link the external pot with the mountting holes
      You can, as Bernte says, replace the trimpot for an external one... but you can also use the trimpot as a preset and cut the link between the 2 pads , then use the two holes to connect in series with the trimpot an external potentiometer.
      That way you can set with the trimpot the shortes delay (for the coil you use, so it still works) and use the external potentiometer to set the delay a litlle longer away at the point were you have some disc for alu foil..if needed
      Succes and make many finds !
        The kit I supply has an external pot for Thresh not delay
          doh! thanks all.
          thanks all, just too excited, on closer examination found thresh pads!
            just finished putting the barra together, i have a gp3000 coil to connect, it has a 5 pin audio type connector, does anyone know which wires i should use?
