Originally posted by Ferric Toes
View Post
The GB systems for CW and PI systems are not analogous. When you bounce the coil up and down, you are looking for a gate position where a zero crossing occurs. Then, the portions above and below the base line cancel.
The nature of the ground signal is irrelevant. When the sampling gate is centered over a zero crossing you get a zero output, whether the signal is purely reactive or mixed with a viscous component. However, when the relative magnitudes of the reactive and resistive components change, that cause a phase shift of the received signal and the gate is no longer in the correct position.
I've read reports that in some areas, you only need to walk a few feet for the balance to go out of whack. This would not occur if the ground were homogeneous. But you're right, the ampltude variation does not matter--the portions above and below the base line change in synchrony.
At any rate, I think discussing these matters is important. It will lead to a better understanding of the problems and it may even lead to the Perfect Ground Balancing System,
Allan
