Main issue with op-amp\diode based log-amp is not log-linearity, but open loop BW limitation of amplifier used, limiting it's dynamic range. Tried using LM318 and diodes at 32kHz and get stucked. Multistage designs are complex and usually high precision components are needed (tried to rip-off design from old portable Tek spectrum analyzer time ago, still have hardware, worked). Nothing can be achieved without some silicone. Remembering AD606 obtained for 125E (around 160$, over ten years ago!), i just dismissed any idea to use something similar for hobby. Today, useful chip like AD8307 is 12.5E (reichelt.de), acceptable for design. Just to figure out how to use it optimally, rules are different, band limiting, no need for DC coupling, extreme dynamic range to deal with, chips are log-amp\detectors giving absolute values... If you think you have no problems at all in your design, just add one, situation will change dramatically
. I get used to spectrum analyzer log display, but observing time domain process on scope this way is something one have to get used to...
What i'm doing here is to just try to utilize log-amp to extract some parameters from test setup, but for actual use in MD one criterion must be met: it most solve more problems compared to what it can produce, so i'm far from strongly advocating log-amps in actual MD design. May be changed...
