Redheat lightning trouble
  • Redheat lightning trouble
    Hi everyone i modified a redheat to run on tesoro 5 pin coils with great success but i dropped it on the floor and now when i turn on detector all i get is a continuous sound does anyone have an idea of what i have damaged ? tried a diff coil still the same ,i did notice some of the shielding had broken off from inside the unit,any help would be most apreciated
    Ummm.. Something other than the coil.. If it's physically damaged then you might be able to see it. I seriously doubt anyone is going to isolate your problem with that level of detail.
      No Earthly idea... you'll need to open it up and see if something's obvious.
        opened up
        [QUOTE=Carl-NC;168028]No Earthly idea... you'll need to open it up and see if something's obvious.[/QUOTEyes its been opened up and i can notsee anything out the ordinary
          I hear the circuit board was covered in black epoxy...?
