First of all-I apologize for my bad English!
There are several issues that I would point out!
-Good coil MUST have good Q-factor!But-I was unable to find single word about Q-factor for RX/TX coils...
What about old rule:acceptable Q,we shall get if C has capacity in pF as wavelength meters!For example, 1000pF for wavelength of 1000 meters.It is not best possible Q but if we do not have abilities for Q measuring,that is good enough!
-If we have problem with coil nulling (TX signal canceling in RX coil),WHY TX unit is not screened or shielded?For good separation between TX/RX,TX unit should not be even on the RX PCB,in effort to minimize influence of TX signal on RX circuitry,would be reasonable to put TX circuit in separated PCB,and then make good shield in form of metal box!By doing so-one can be sure,that there is no TX signal coming from unvanted coupling between PCB tracks or component mounted on PCB!
-I have no illusion about noise!Since we are not talking about space communications,we are free to forget about noise in kHz spectrum!
So far-this is enough!Any opinion-suggestions about mentioned issues are very welcome from me.
Thank you in advance!
