OP-Amps in a can...?
  • OP-Amps in a can...?
    Hey all,
    I have a couple of questions.
    I currently use a DIP version of the TI LM4562 ( http://www.ti.com/product/lm4562&lpo...native_Devices ) in my machine.
    The .pdf above shows the metal can TO-99 form factor as a completely different design choice vs. DIP or SOIC. Why?
    What, if any, advantage would this packaging present?
    Is a metal 'canned' amp shielded from noise better, or...what?
    Just wondered,
    GTB
    Generally speaking, yes.
      Canned devices tend to pass harsh environment specs with flying colours (e.g. radiation), and often are capable of handling more power, but that's about it. You could even attach a heatsink to them, but in most cases it is useless for you.
        In most cases the surrounding circuitry has to be shielded from noise as well, such as feedback paths and input impedances, so only canned circuit module devices enjoyed a noise advantage.
        At some point in history canned and ceramic packaged devices offered better aging properties, but I think it's not as much of an issue with modern devices for our purposes.
