I am just starting on a project using the latest revision of Gary's PI. The goal is to use multiple small coils mounted in a linear array. The output from each coil would be displayed on an LCD graphics display as a scrolling image. So passing ove an object the display would create a 2D image of the object. My main goal is to use this underwater looking for lost boat anchors. Of course since Blackbeard was married and lived in Bath,NC - which is only 30 miles from where I keep my sailboat, I am obligated to go look for his booty :-)
In reading Joseph J. Rogowski paper "Making a Fast Pulse Induction Mono Coil", he mentions that one of the items that slows down a coil's pluse is the output capacitance of the MOSFET driving the coil. The MOSFET I have seen used by designers here is the IRF840. It appears to have an 8A continuous capacity, 32A pulse, reverse breakdown voltage of 500 volts and a COSS of 310pF. In reading threads on Geotech1. I have seen mention of reverse spikes of over 600v. In doing a little searching, I found the STD6N95K5 which has 9A continuous capacity, 36A pulse, reverse breakdown voltage of 950 volts, on resistance of 1 ohm, and a COSS of only 30 pF. Is there something I am missing, but would this not make a better coil driver?
kind regards,
David
S/V Night's Beautiful Daughter
www.dv-Fansler.com
kind regards,
David
www.dv-Fansler.com
