Final tersting of DIY Bandidio umax2
  • Final tersting of DIY Bandidio umax2
    Hello all. I am going to cut out as much of the 'grammar'
    as I can and just note the facts, sort of.
    Found old Forum on Web: Guru posted " must be 300mV pp at o/p of receiver opamp".
    Checked mine : 600mV and bad crossover distortion. Fixed Xover with hard pull-up
    (LM35.Found horrible waveform at output of DISC op amp. Sort of damped oscillations.
    MC33178 (same as Tesoro) arrived in post.Removed pull-up & LM358, fitted it. No Xover,
    horrible wform gone - was slew rate then.Still got 600mV pp.
    Bought some unknown coils on Ebay, 3 for £5.00 - worth a punt.
    Tested mine (10" - ooh Matron. You need to be English
    ). Tuned at 10kHz
    Dime detected at 15cm (yeah, been across the sea a few times).
    1" washer det at 17cm.
    Tested 7" unknown from Ebay. F went up to 13.86kHz 300mV pp as ordained.
    Dime at 16 cm, washer at 19cm.
    Ground balance much better.
    Minor mod to 4024 (use pins 6/5/4 - more pleasing tone.
    My unit now 99% as Tesoro design. Shame.
    First board I made had faults. Fixed it, sprayed with conformal coating, ruined it.
    Built another - much better layout, used almost same parts as Tesoro. Way way better.
    I guessed Freq when I built - didn't know what Bandido runs at. Seems my coils are crap -
    but I did make all the rest, twice.
    Planning field trip after good back garden tests.
