help with surf pi kit no sound
    Originally posted by alcartraz View Post
    just had another look am i testing it right - test from multimeter to ground + to legs of u5 pin 3 11.7 bat volts same pin2 1.48 pin 1 10.48 and yes i need to put new bats in thank you for helping
    Since pin 2 (middle pin) of the regulator should be at 0V, and you have the negative terminal of the voltmeter connected to 0V (I presume), then you may have a break in the ground somewhere. Try doing a continuity test from U5 pin 2 to the negative battery terminal. These two points should be connected together.
    Think about it.
    How can there be 1.41 volts on the regulator GND connection?
    Is this a Siverdog (Surf 12 "ApB") long board PCB, or have you made it yourself?
      Think about it.
      yes the silverdog long board from +bat to pin 2 15.55 volts continuity from pin 2 to batt - is good from - batt to pin 2 1.37 volts iam lost ??
        OK, let's try a different approach.
        What is the voltage between the GND and OUT pins of U5?
        Put the meter probes directly on these pins.
          17 to 18 volts fluctuating
          input 11.37 all on the pins of u5
            right just tryed an old lcd multimeter i had kicking about i have got different readings pin 3 in 11.4 pin 2 0v pin1 out 10.5 that was measured - to ground + to pins on u5 now measured on pins pin 2 and pin 1 11.1 volts ?
              It appears that the previous meter you were using was faulty.
              As the output should be 5V, I suggest replacing the regulator (U5). Then take the measurements again.
                hi sorry people confusion set in i was testing q2 instead of u5 because q2 looks like the regulators i use in power supply i used to build in my job now tested u5 volts are good 11.4 going in 5 volts coming out i gess stress and trying to do many things all at the same time ?
                  the regulator is ok what do i test next ?
                    Check if the negative supply is working by measuring the voltage at pin 5 of U6.
                      i got 5.22 volts on that pin
                        It should be -5V (or close to this value). Note: It should be a negative voltage.
                          new batts u5 output 4.96 pin 5 of u6 - lead of new meter on ground + lead on pin 5 of u6 is -4.75 volts ? is that right
                            That looks good.
                            Now (before we proceed any further) please measure the voltages at:
                            U1 pin 8
                            U2 pin 7
                            U2 pin 4
                            U3 pin 8
                            U3 pin 4
                            U4 pin 14
                            U4 pin 7
                            U7 pin 14
                            U7 pin 7
                            U8 pin 8
                            U8 pin 4
                            Please note if they are positive or negative voltages.
                              ok they look all good
                              u1 pin 8 v12.40 +
                              u2 pin 7 v 4.97 +
                              u2 pin 4 v 4.75 -
                              u3 pin 8 v 4.97 +
                              u3 pin 4 v 4.75 -
                              u4 pin 14 v 4.97 +
                              u4 pin 7 v 4.75 -
                              u7 pin 14 v 4.97 +
                              u7 pin 7 v 4.75 -
                              u8 ? well i cant find that one on the parts list
                                u1 pin 8 v12.40 +
                                u2 pin 7 v 4.97 +
                                u2 pin 4 v 4.75 -
                                u3 pin 8 v 4.97 +
                                u3 pin 4 v 4.75 -
                                u4 pin 14 v 4.97 +
                                u4 pin 7 v 4.75 -
                                u7 pin 14 v 4.97 +
                                u7 pin 7 v 4.75 -
                                Sorry, there is no U8. That was a typo.
                                OK - let's proceed step by step.
                                Can you monitor the following points with the scope and post the waveforms here:
                                U1 pin 3
                                U2 pin 6 (TP2)
                                U4 pin 10 (TP1)
