I would say the "laminate" would be double sided printed circuit board.
Underwater PI detector
Geo I tried to find the thread with a very good housing for surf PI
that has "O" rings till 3:00 am , but gave up.
I only have kept 2 pictures that show the "O" rings
somebody may recognize the pictures and remember the thread.Attached Files
Originally posted by Geo View PostWM6, seems good solution but i can't understand what you mean with laminate. Google translate don't help me
I do not know greek or other english term for Cu laminated vitroplast.
Originally posted by 6666 View PostGeo I tried to find the thread with a very good housing for surf PI
http://www.geotech1.com/forums/showt...492#post131492
Originally posted by Geo View PostI finally made the Surf_PI with the pcb designed by Aq. Thanks to Aq and to silverdog for his very very quality pcb.
Now is time for the water resistance Box.
Slowly... slowly as the years passed
please could you show me the Schematic and pcb design of Aq and to silverdog
thanks
For new machine I have purchased one more on eBay for record low $8 with free shipping recently.
But you need to cut longboard to let if fit.
Originally posted by Geo View PostBtw.. don't you use potentiometer for threshold???
But I can really recommend you to have SENSITIVITY potentiometer to adjust your machine for example when you go from dry sand to salt water.
Best potentiometer is that one from WestFloridaComponents.com !!! BECAUSE IT HAS O-RING INSIDE TO BE WATERPROOFED !!!
http://www.westfloridacomponents.com...ST+Switch.html
Anyone can tell what a thread it has? They do not offering nut so I screwing it into plastic pipe piece.
Also there is ABSOLUTELLY GREAT STUFF TO WATER SEALING ANYTHING !!! 10 TIMES !!! MORE STRONG AND ADHESIVE THEN SILICONE !!!!!!!!!! AQUASEAL !!!!!!!!!! Search eBay for "Mcnett Aquaseal Urethane Repair".
I am fixing my scuba boots with it every month instead of buy new until felt wears off and it has holes on the bottom. :-)))
Also it is great to seal coils, cables, pots, phones, e.t.c.
Originally posted by Waikiki_Sweep View PostI am using "Snap Sights Flash 35mm Waterproof Underwater Reusable" camera box. It works for me 3 years already without problems.
[ATTACH]26374[/ATTACH]
could you upload this photo in its original file and please if you have its PCB just upload it also
and also the list of components
i will be gratful for you
thanks in advance
Mohamed Ghitas
Hi Waikiki_Sweep. I'm searching for a way to re-use Li-Ion batteries in my MD's, and one of the things I am having difficulties with is to find a DIY charger that I could use with confidence. Can you tell me what kind of charger you use for your MD? it would be great if you have a schematics too.
Thanks in advance.
Fabian
