Pls can anyone tell me more about a detector called a chance pi...is there a diagram for building this detector ????
CHANCE PI CIRCUIT DIAGRAM NEEDED
Here http://md4u.ru/viewtopic.php?f=5&t=3033
and here http://fandy.hut2.ru/Chance.htm
Only there in Russian---use online translator....
Here is a pdf. But you must use an online translator for building this rig. I don´t know if it is the newest version.Attached Files
yup. Andy released Minelab patent on a disc in PI... he did learn it... I read comments and they are too different... someone writes it is, another one writes it is not... very specific may be and not so due precize dsicrimination you are waiting from...
anyway, you will decide... your word will be last point in the matter.
Originally posted by kt315 View Postyup. Andy released Minelab patent on a disc in PI... he did learn it... I read comments and they are too different... someone writes it is, another one writes it is not... very specific may be and not so due precize dsicrimination you are waiting from...
In July I asked Silverdog aka Andy Beasley if he had any CHANCE boards and he did not at the time. I believe that he will have more made if people contact him on his site and ask for them to be made available. He also sells complete board kits. I have built two of the boards from Silverdog and they are very good. One of the boards is being integrated into a complete detector this week after the case is painted. The prototype detector I built is somewhat detailed in the 'CHANCE PI build' thread on this forum.
Dan
Originally posted by daverave View PostPls can anyone tell me more about a detector called a chance pi...is there a diagram for building this detector ????
You will see in the build instructions that you must adhere to the author's coil design and you must use the 390 ohm damping resistor because the software was written for those parameters. I find that these requirements are overstated and the detector operates best with other coil designs and damping resistor values optimized for each coil. My purpose in building CHANCE is to find sub-gram gold, i.e. 5 to 15 grain nuggets...larger is good too! There are many modifications to the original design hardware that make the detector better and searching this forum is a good place to learn more.
Good Luck,
Dan
i really want to have a crack at making this detector...im told silver dog has no more pcb's for this chance pi...so where can i buy one from and the programmed pic chip ??? could i have a pcb made by a commercial company by giving them the art work found on this website ???? i know very little about making a pcb or sending a diagram to a commercial company...can anyone pls advise.
Originally posted by daverave View Posti really want to have a crack at making this detector...im told silver dog has no more pcb's for this chance pi...so where can i buy one from and the programmed pic chip ??? could i have a pcb made by a commercial company by giving them the art work found on this website ???? i know very little about making a pcb or sending a diagram to a commercial company...can anyone pls advise.
