Originally posted by Davor
Insrumentation Amplifiers Help
Originally posted by Brian Deese View PostI had a good long read today,I have a question regarding analog ground. In the book Inside the metal detector,on the PI designs there is a voltage divider and an opamp that supplies analog ground 1/2 battery voltage.Now on my battery that I plan to use for my project the cells are exposed and I can get to the center of the battery no problem.I can solder directly to it and take it to the board.Which is better? I can see it either way. I am going to guess divider and amp is better because if one of the cells discharges slightly more on one side then my voltage will not be in the center anymore,correct? Its a li-ion batt with four cells, btw.
Originally posted by Brian Deese View PostThat is a swell article,I may have that printed.The 33uF caps they use,do you think they are electrolytic? Thats a pretty big cap.
