ART WORK ON HOME MADE DETECTOR
    that would be great idea to set up graphics thread....i just want increasing/decreasing curve as seen on a lot of commercial detectors and the normal 1-10 numbers around volume control...is there any freeware that can do this ???
      What kind of graphic are you thinking of for tuning and volume up and down? The P-Touch has a wide and varied character set that is scalable. I'll try to find a site for that for you to see. The labels will stick to film or the substrate behind the film.
      You do not need special or sophisticated tools.
      Such graphic can you draw by using simple and widelly awailable tools as MS Paint:
      At back side put duble-sided adhesive tape, and front protect by transparent adhesive foil
      and you have self-adhesive "plastic-laminated" control front end for your apparatus.
        I use a P-Touch labeler by Brother and clear label tape in 1/4", 3/8", and 1/2". It uses the TZ series of label tape cassettes and they come in a variety of widths and colors. It prints multiple lines of text depending on font size and tape width. It is self adhesive and very durable. I find the 6 and 9 point fonts to be most useful for labeling controls on my BITX 20A ham radio and on my CHANCE PI detector.
        Dan
        are the labels like thin foil or like the old dymo type thick labels ????
          [ATTACH]26573[/ATTACH]
          yes thats what im looking for as on your volume control and also i want 1-10 volume scale.
            yes pls show some examples
              The labels are very thin and self adhesive, not like the ugly DYMO embossed labels.
                You can GOOGLE 'Brother P-Touch Labeler' and see examples of the label quality on their site.
                  I am working on posting some PIX of my completed CHANCE PI with those labels but have to reduce the pictures megapixels before I can post them.
                    frontdesigner
                      To draw circle with MS Paint in different divisions, you can use circle division template from this site:
                      http://www.enchantedlearning.com/gra...zers/piechart/
                      So you can draw your own front elements like this:
                      and using your elements create in MS Paint your own Front design:
                        i like your layout...thats what im looking for and does the $5 dvd have all this on it so i can print my own decal ?????
                          Finish (again):
                            frontdesigner
                              Dave, mine version of Radiofactory is Russian translated... I do not know where keeping English version you could take if you need I will share some my FPL files for the soft I made and you will be able to begin make own decal... Radiofactory is simplest soft to use IMO.
ID:	337894Click image for larger version
ID:	337895Click image for larger version
