build twin loop teasure seeker
  • build twin loop teasure seeker
    I am building the twin loop teasure s. but non encounter the IC A709cp. my question is... That replacement I can use to replace this IC?
    Help me. Please!!
    Thanks.
    Re: build twin loop teasure seeker
    Any kind of 709 work. You can replace this by the LM318 with the necessary modifications.
    I replace the normal TIP 31 by TIP 112 or TIP 122 darlington transistors. I hope the pinpoint version coil is better.
      Re: build twin loop teasure seeker for
      Of which type of modifications I must do?
      for replace 709 for lm318
        You might try an NE 5534 first without making any changes and see what happens. It just might work. If it doesn't, it shouldn't take too much to make it work.
        Example, you might have to reduce the value of R 16 from 390K down to maybe 100K if you cannot balance the output of the opamp.
        Reg
          Why don't you use the LM709 from National Sem.
          Greetings from Austria!
          Norbert
          LM709
            Re: thanks best regards
            gracias a todos
