XLT damaged: Help needed
    Well the way to troubleshoot that is to start lifting pins. Using a good low ohm meter measure the different
    power pins unsolder and lift the one that reads lowest. Keep going until the resistance jumps.
    Say the +5v to ground reads .5 ohms on one pin and .6 on another lift the .5 ohm one. It might just be one
    component that goes first. Anyone have experience fixing these?
      main rule if you got a trouble for any PS (power supply) - check all low-ohms resistors and all diodes AT FIRST there. try get +5V on C32 (NOT on output of LM2574-!).
      then after, search the converter -5V.
        Hi all, no one has good quality and complete scheme for XLT?
