PI metal detector problem in my circuit board
  • PI metal detector problem in my circuit board
    hello everyone I have in the trouble with my PI metal detector which made by myself. My circuit board related information and my problems are described in a picture and you can get is in the attachment. My problem is that when i supply the power to my board, i found that the falling signal transforms to MOSFET drive chip(TC4420) by the micro-controller disturbed by unknown signal form my board and the flyback signal generated by the board is not right.
    I am very looking forward to your help,thank you!
    How can i insert my image??
      after you have wrote your first post you may insert image in following.
        Can you tell me in details,can give me some step or others,thank you very much
          http://www.geotech1.com/forums/faq.p...b3_attachments
            problem of PI metal detector.pdf I have post my problem in the attachment, I am honestly looking forwarding to your help, thank you very much!
              Hi Lou,
              You will need to amplify the signal before you will see anything on the oscilloscope. Try with a gain of about 50. You might get a signal that has a peak of about 1v.
              Cheers Mick
                Originally posted by Mechanic View Post
                Hi Lou,
                Cheers Mick
                Thank you for your reply, I will test it with an amplifier to amplify the signal. but i still confused that the signal produced by my circuit board whether ii right or not.
                I have refer to the circuit diagram, in his diagram there is no amplifier come consequently after the signal produced by the coil. And I found the video the signal is very good generate by his circuit board. This is a link to the paper described how to make a PI metal detector http://www.miymd.com/index.php/projects/tpimd/ , and video link is http://www.miymd.com/files/3113/0305...1_0820_776.mp4. The circuit diagram is Click image for larger version
