wireless headphone système 433 mhz .
  • wireless headphone système 433 mhz .
    hi, I finished my wireless audio system, I leave you some pictures and a video.
    https://www.youtube.com/watch?v=UsfBpvS3l10
    nice work nico, i wonder if the receiver could be made smaller the transmitter does not matter, but made smaller i could put the rx in the left cup of some headphones (deaf in one side anyway), i usually have just one cup on my phones, but i would go back to two to make them wireless.
    when i'm on the beach the wire gets on my tits, any chance of the schematic, parts list etc.
    thanks aly.
    p.s. the plastic version of you rx box is what i used for my barracudas, the smaller square one for the batteries, exellent cases.
      Good job, Nico.
        we have discovered that the system that is used by the brand XP metal detector is the same as used for 2 modules sold by Aurel marqur TXFMAUDIO and RXFMAUDIO. This morning prospecting with a friend he had a wireless headset brand XP metal detector and as soon as he had started it the TV reception issued by my camera aurel TRANSMITTER signal. and vice versa as soon as he put his detector road I captured her in my aurel detector receiver
          i'm currently researching the possibility of using fm radio band, after reading your thread i remembered i had a pair of those headphones with an fm radio built in, i plugged in a cheap mp3 transmitter in the MD, it worked well but the range was way more than i need, so i will make my own fm receiver board for the phones, tuned to the mp3 transmitter.
          but thanks, if i had not seen yours i would not have thought of it.
            ok , ok, I also think a FM system, the MAX2606 VCO apparently works well in 88-108 in issuance so. I found a miniature pcb on the web at this address. es, but it will not be disturbed by the external environment?
            here is the link in the pcb so smd.
            http://www.electronics-lab.com/proje...017/index.html
              Hi ashefr,
              I've been looking at the internet but it seems Aurel has a few modules.
              Do you know the exact type of module that was used?
              Was it the Aurel TX-FM-MID/EN FM Receiver Module 433.92 MHz?
                hi, modules are used aurel :
                http://comelec.fr/recepteurs-rx-audi...eur-audio.html
                http://comelec.fr/emetteurs-audio-vi...-fm-audio.html
                it appears that one can use other modules that run on the plurality of detectors are modules 2.4 GHZ. are found on ebay at:
                http://www.ebay.com/itm/2-4GHz-NRF24...E:L:OC:FR:3160
                  Thx ashefr10!
                  Will try to play with it. Results will be posted.
