some known good ways to trickle charge your batteries and give you free electrons
as you move and in the light {or dark}
get a skip cap cover it and the sholder pads and back of your jacket with imorphoss panels you can get them cheep
they will provide 3v at ma each 100 - 300 in sunlight as much as 400 from some small 3vcells
{dont worry about the burden of looking less cool you already look like a prat with a metal detector how much more excuse to you need}
i also see a rather large panel that can charge a 12V cell car battery fully in 1 day
for us money about 120$ here is 80£sterling ?? i think its about that ball park
in just normal light
so in sunlight i think it said 2 -3 hrs
if a detector uses 12 V 1 amp or 2 amps peek for 30%- 80% duty then you can easy get enough from a skip cap and two lappels cells
this will give lots of potential and a good few ma
why waste time recharging
simply recharge on the fly.
If you junk wind upradios they give some rather nice bits and bobs a set of 3v solar cells X3
inc the charging winder this provides 3 v each one at 50ma
7 on a belt run the complete unit
charge the battery and a spare,
so in bad light your up with a shout ....
you can use switching diodes 1n5403 and a zener same volts as the supply needed in a T branch to switch over when volts is low
there are several wind up items that give various power when wound to the top
some 1 hr some 3 hrs of 3v 50 ma
other ways come from the gold pic fellow
he uses a weight in his shoe heels and rectifies the sine wave to give dc {totaly useless unless you jog with a detector and he gave up ah mr hill seen him on tv}
i found that having a plug that fits into a lightbulb socket has been handy in the past
and using a good set of nickel metal hydryde for pi {from racing cars {toy ones}}
you can buy and scrap cheeper than buying the cells {as with most stuff junk parts rules...}
makes a very a good time period when
using a hungry cpu driven pi {not so very hungry cpu using very little when you move into an smd version from the bigger dil and sil stuff as much less as 20% of dil and sil usages {incidently smd opamps use 5ua as opposed to the bigger sil and dil that use as much as 10 - 20
also helped by a seperate free as you go type supply
the addition of any 555 using a u555 or a cmos version it uses 5ua or some as little as 2ua to run its logic as opposed to an ne555/6 that uses 50 ma big differances like this make for poor designs like pi pola ne555/6 and dogie timing when the battery is zapped
avoid using too much pi power so some sort of auto power adjust is needed
this is the end of the free energy systems i can think of
and ways to save da juce......
other than to say
the best way is to leave it in a cupboard and go dig lots of holes instead.......
but by far and the best way is what i plan
and this is to incorperate this design
http://homepage.ntlworld.com/vsm.libs/DESIGNS/water.exe
into a metal detector using a very small turbine {gas driven from water rectification using pwm }{like an electric lighter size
into a psu
then there is no need of dumb batteries of crap limitaions on current
and it runs on water as a semi sealed closed system.........
what do you think about this method
i am keen to know
{no laws of or about conservation of energy topics and this wont work becouse comments this is pwm multielectrode not dc with laden jars thankyou........}
i put this here becouse it is a good way to get clean free power for detectors and monitors etc that can be used when needed
and helps to save the planet by not requiring a cell to store potential
this way also stopping battery polution
just look at mexico ooozing rivers of sulphuric efluent miles high mountains of redundant batteries
other than to say
into a psu
i am keen to know
