silver sabre
  • silver sabre
    I would build the silver sabre.On 4 april this year BG post the circuit on this forum.Marcello post a circuit on 18 august of the silver sabre.Which one is the right one. Can i replace the LM2930 to 7805? Has anyone a pcb? Which coil? I found in a dutch book of metaldetectors : tx 100 turn of 0.5mm copperwire and a diameter of 200 mm and rx 170 turns of 0.5mm copperwire, diameter 80mm
    Re: silver sabre
    Hi Rudi
    You can replace lm2930 with a 78L05 or a 7805, better low drop version.
    The info on coil you find in the book are incorrect.
    Try A DD coil 20 cm diameter and 130-135 turns of .25-.35 mm.
      Re: silver sabre
      Any have the PCB of this circuit?
        Re: silver sabre
        The Eldorado is better of silver sabre!
