PIC's AVR's, HC11 ADCu812 ,etc in detectors
  • PIC's AVR's, HC11 ADCu812 ,etc in detectors
    Hi folks!
    I have been foolowing Carls and Holooks digital
    design efforts and the following discussion
    about MCU's to use for MD's.
    This summer during 2002 i designed a MD around
    the 5521 IC from philips what a damm neat singel
    chip MD it went out to be. So then i started the
    Digital MD project after his nice description of
    the project he runs and its progress.
    But since i have zero kowledge in programming
    there was a lot of whoe's and wheee's about the
    whole thing.
    I started out with the HC811 but gave up since
    MOT decided to do EOL of that Devicet, then i
    swapped over to PIC16F887 that i "tought was
    easy which is not and got upset when i found
    out the "crap" bank switching sceme! Pic to the
    dust bin, then i swapped over to the ATMEGA16
    because of the exellent AVR studio tools but
    i trowhed up at the 136 instructions??
    I tought RISC stod for "reduced, not extended!!
    But by sheer coincidence i found out about the
    MSP430 from TI! I jumped directly for that one
    because:
    1:Extrodinary low power! (Battery saving).
    2:Unbelieveable simple to program, 27
    instructions, very clean and straightforwad
    core design.
    3:12 bit ADC allmost automatic. 1lsb
    (not the best but its there anywhay!)
    But there are devices whit 14bit ADC!
    (so that would perhaps satisfy Carl and
    Hoolok!!)
    4:MSP430F148 has MAC unit!! (Horray,DSPing for
    MD signals) this is great for Pi or odinary
    detecting, the Mul unit does 16 by 16 mul
    with 32 bit result wich "would" eventually
    satisfy for PI detectors!!
    5:A decent dev kit including fully functioning
    C compiler(4k limited) but assembler has no
    limitation. GCC available allready for those
    who code in C.
    6: The machine is a 16bitter and its placed
    in the cheapo range of the PICs and AVR's.
    After initial Dev tool setup bug i had written
    my first program in less then 2 ohurs, this
    would not have happend to me with any of the
    other mcus! This is no TI advertising it is BJ
    advertising because can a goof like me who has
    never programed before write a working program
    in less then 2 ohurs from scratch with all what
    that means in reading manuals,learning
    instruktions, etc etc etc. There must be
    something neat with the damned thing!!!
    Yes, there is minuses as well with the MSP430
    and the manuals are somewhat messy but it so
    damned simple to program!
    Have it for a try, free samples and cheap
    starter kits are available. Simply order from
    TI!
    REG
    BJ
    Re: PIC's AVR's, HC11 ADCu812 ,etc in detectors
    BJ
    I took a quick look at the MPS430f147. The CPU seems to be fast enough and it has a good CPU architecture without bottlenecks. If I understood the ADC it looks like it can do about a 300 kHz conversion rate though I could not find that number anyplace. This chip looks like it would be good for metal detectors. It is even fast enough to do a lot of it in C.
    Robert
      >The CPU seems to be fast enough and it has a >good CPU architecture without bottlenecks.
      Yes that striked me to when i saw it the first
      time. A real bonus are its low power for field
      applications such as MD.
      The "experienced" people on the MSP430 list
      say this also that the MSP gives many other MCU's a big kick in the rear end!
      >If I understood the ADC it looks like it can do >about a 300 kHz conversion rate though I could
      I find speeds of 200ks for the 12 bit ADC some
      say that its possible to strech that a bit by
      overklocking the ADC clock. There are
      independent clock system for the CPU ADC
      and the timers.
      TI claims due to the straight forwardness of the
      instruction set that C is very well compiled, they might have a point there but it depends
      also on the C compiler. Im at the moment to
      green to judge any C system so i leave that to
      other who knows better.
      But there are two distinctive features that i
      find quite valuable for my purposes, that is
      the Jump of 1024 range and the symbolic adressing mode.
      REG
      BJ
