Originally posted by Qiaozhi
View Post
When you use a PI detector with a mono coil, the target is detected purely by eddy currents generated
in its surface.[but through the Eddy current is a Magnetic Field generated] Depending on the size of
the target, its orientation and conductivity; these eddy currents [and the Magnetic Field] the continue
to flow for a given time. [at this time the Magnetic Field of the target, works against the Magnetic Field
of the coil, through this the Magnetic Field of the coil takes longer to go away on the end of the puls.
The flyback will take longer] work If they have not died away by the time the main sample is taken,
then the target can be detected.[If I understand correctly, the PI measures the duration of the
obstruction time of the Magnetic Field of the coil through the induction of the target.
The operation of the PI detector is on the same basis, just another detection method but the coil
receive not the target signal.
It works on the change of the Magnetic Field of the TX through the induction of the target who opposes, is that right?]
When you use a continuous wave detector (often referred to as a VLF) the small eddy current signal from
the target is swamped by the TX signal, so it is necessary to blank out the TX using a different method.
In this case, the TX and RX coils are positioned in such a way that they are in what's called
"induction balance", and any target signals can readily be seen, even though the transmitter is
still running. Because the detection process involves monitoring the phase-shift of the received signal,
[This, I do not understand, how can the RX receive while the RX is nullit. He even receives
almost no signal from the strong radiant TX, much less a small signal that first must penetrate through the soil to the RX coil]
it's not immediately obvious that detection is still the result of eddy currents flowing in the target.
[when I look at my theory that's for me clear why the RX can not receive and it is not necessary that
the RX recieves a signal from the target to detect a target].
nupi
