PIC, etc, I forgot to mention!!
  • PIC, etc, I forgot to mention!!
    I forgot to mentinon that the dev tools
    are "free" ar called "Kick start" the kit
    contains, relocatable macro assembler,linker
    C compiler,simulator and Flash burner and a debugger.
    It is simmliare to the AVR studio and MPLAB.
    Its not as good as the AVR Studio but its a
    hell of a lot better then MPLAB 16 bit crudity!
    REG
    BJ
    Re: PIC, etc, I forgot to mention!!
    i think BJ you got stuck at mplab not pic micro
    i fully agree the lowest form of life mplab much like the bacteria it is it is only good for assemling other low forms of life
    called macros
    these can also be writen in c langages like CCS and hitech
    these cross macro compiles
    do a far superiour job
    after all the guys who write mplab know that it is a "low level macro assembler"
    BUT what i dont agree with is tossing something in the bin
    instead of using some descent software to write your program
    forinstance
    a serial coms from a pic16f84
    the would take half a chip too do this using pic mplab langauage
    but by the miricle of science
    and macro driven c compilers
    you simply write a one line comand like
    ser in or ser out and send a string
    this makes things like ports and how to use them without floading the ship
    easy stuff
    as the cross compiler simply inc all the right stuff for you
    so crap are they
    they are used in 50% of mcu casses
    with the biggeset use being most bank cards and just about all smart cards
    pic 84c versions.....
    other than too add
    simply port load a byte rather than switch ports then send individual commands
    do this on an interupt
    so as each task is finished it will interupt back to the control routine
    i will agree someone with no nothing experiance of programing
    shouldnt even concider mplab
    and instead start with picbasic before moving on to macro c languages like ccs hitec gnupic amoungst others
    i can compare your situation with
    getting a spectrum for xmas and only having a low level assembler compiler to use to write the command set you still need to make it work
    never having realised the assembler your using {mplab} has no librarys of upper functions
    so your barking to use mplab in the first place for pic mcu
    i agree dsp can be good
    under the correct conditions
    so knowing this TI simply make higher level functions in there lab already macro driven {past the mplab stage}
    so inexperianced programmers like your-self's
    have no problem to understand whats going on
    and what functions you need
    ie they give you an operating system with your spectrum
    pic's have there place
    and as was pointed out in a heated debate below topic's
    dsp's do also
    {at the heart of every dsp lives a risc micro at the heart of every pic lives a dsp}
    if you know how to use them correctly
    without jumping up and down on the spot
    or resorting to mplab
    your laughting
    as you will soon discover....
    when 4 metal engine is finished
      Re: pic etc barriers
      however
      my strongest advice is
      do the pwm with a smaller type of pic like an 84
      make a rock solid tight routine for shifting into the pwm port or ports..
      on interupt any data from the sampling chip controler chip {877}
      this way you can then base your flow on a chip routines and codes that never stops running
      instead runs in RT
      {this way you can sync the sample gates and the pwm to the driver fet and simply using the same xtal for both micros get rock solid continuious pwm}
      while the other gets on with the a/d and control
      a TI mcu costs much more than just an 877 $1.99 and an f84 99cents {my local shops pices are £1.99 and expensive £4 for the pic 877 20mhz
      for the TI chip it costs £140 for the single platform dev kit and nearly the same if you just buy a chip
      direct i dont know ...???possibly 20 - 25£
      so for pics if i buy them from the states instead
      or simply ask for a sample from microchip
      i get them cheeper or for no cost
      but
      the cost is in the software you use
      and CCS is the best one for pic
      with hitec having also some very competative extras ......
      these cost about 200- 300 US$ for a descent usable package.....
      with pic basic costing 250US$ the c versions makes sense if you already have any sort of foundation in c at all
      as for picbasic
      well this is very usefull
      runs a little slower than c
      until you optimise the routines using a few tricks....
      but good to learn pic from a distance
        p.s
        if you think mplab and pic is bad
        try a non risc core like a z 80 or a 6800 or 6502
        then you will beg pic's & mplab for forgivness...
        i have done all this before
          Re: pic etc no barriears only possible solutions.
          >pices are £1.99 and expensive £4 for the >pic 877 20mhz
          I dont know where you are buying and in what quantity but even if i buy 877 in 10's i have
          to pay at least 10USD each. For me the price
          is not the factor who decide.
          >>for the TI chip it costs £140 for the >>single platform dev kit and nearly the
          No, i pay aprox 9USD for the MSPF148 in 10's.
          And there are a whole line of "lower priced"
          units.When it comes down to pricing nor TI or
          PIC or anyone else are not foolish enought
          not to make competetive pricing.
          Its simply regular marketing behaviour. MSP is
          a rather new device, its un advertised, not
          yet fully supported by the comunity its still
          16bit has MAC unit, are simple to program.
          And if you had checked out better you would
          have found out MSP EVM's for 49USD inc soft
          wich is less or equal the rest MCU
          manufacturers offerings.
          >>the cost is in the software you use.......
          Offcourse thats "why" i using the MSP
          instead of PIC and AVR's,HC11, etc.
          >>PIC,,, using a few tricks....[/i]
          Thats "exactly" what i "dont" have to do
          with the MSP, its fast whith just regular programming!!
          And thats what other PIC programmers have
          found out too!
          BTW ,this starts to sound quite silly,
          arguing about PIC's MSP, AVR etc etc.
          Actually i dont give a **** about TI ATMEL or
          whatever, i simply go to what's understandable
          has low learning tresholds, productive, fairly
          pricing, i dont mind if the crap cost 1 usd
          more or less as long as i understand the thing!
          My posting was only about to inform MD list
          about just "another" possible solution to MD
          design. If people find out that they dont
          like the MSP ,well dont use it then!!
          Simple as that!
          REG
          BJ
            BJ,
            Just got back from holiday today and saw your note. I've already been looking at this VERY nice processor. There is a series of recent articles in Circuit Cellar magazine about it - they've just had a design competition using it.
            It certainly looks like an interesting contender. Its power-to-speed rating is unbeatable...
            Good advice - worth looking at.
            Nicko.
