Since this is a major modification of PICKINI V1/2 http://www.geotech1.com/forums/showt...etector/page13
maybe it's better to start a new thread.
After having built quite a few of the V1 and V2 PICKINI detectors, it was time for some changes:
V3 is largely based on the same principle = flyback pulse width measurement.
This principle is described in the book "Inside the metal detector" on page 170 = PI design 5.
Major differences from V1/2:
The entire description and download section can be found here:
http://users.telenet.be/willaert/MD/.../V3/intro.html
- smaller single sided PCB footprint: [35 x 110 mm] or [1.38 x 4.33 inch] fits nicely in a drain tube.
- simpler power supply: unregulated 10V - 14V DC, so less batteries needed.
- new analog frontend around NE5532 opamp + virtual ground - as described in ITMD.
- smaller microcontroller: 8 pin PIC 12F1840.
- new mechanical design: straight stem from crutch, coil shell and lower stem were bought.
- optional pinpoint pushbutton: switches the detector into non-motion, allowing it to hover over the target
- extra audio signal when no flyback is detected = "coil error sound" - mostly caused by bad coil connection.
