TX Experiments
    Disregard that data above. I had 2 coils on my bench and used the wrong leads
    after changing over to the pnp's. Now putting the 440 coil on it gives dismal results.
    The 12.6 mh has too much resistance to get any power going without higher voltages.
    Maybe make a doubler?
      What about that 470 ohm in between the bases. It reduces circuit gain severely, and perhaps if tweaked correctly you'd get enough gain to supply coils with poor Q as well.
        I tried changing that in the sim and it didn't seem to make much difference.
        For some reason the sim doesn't give the same results as I'm seeing. With
        the Deep Search coil (a Tesoro coil with CT RX ((using the RX as TX))) it
        agreed perfectly to the sim with the other coils specs.
        Deep Search is 6.1mh ct
        440 Coil is 12.6mh ct
        Not sure what is going on....
          No idea. Did you measure the coil resistance and corrected it in sim?
            Yes I'm using the correct resistance.
            I remeasured everything today.
            440 Coil
            12.6 mh total
            3.2mh 14.3 ohms per side
            W 6.8n cap oscillates at 14.9khz
            @7.35V in
            3.1ma in
            25.7v P/P out
            16ma per side
            @5.45
            2.3ma in
            18v P/P out
            11ma per side
            DeepSearch Coil
            6.1mh total
            1.2mh 8.5 ohms per side
            with 18n cap oscillates at 14.5khz
            @7.35v in
            4.0ma in
            25v P/P out
            40 ma per side
            @5.45v in
            2.9ma in
            17v P/P out
            29ma per side out
            I retested the Aziz oscillator which I had rejected due to excessive current draw
            and found I was powering it wrong. It was drawing 5ma from the positive and negative
            supplies but I think it was meant to float between the power rails and not run from +-V.
            So I applied +9v and ground to the power pins letting the gnd find itself and Voila!
            440 coil 9V in
            1.5ma in
            30v P/P
            35ma per side in the coil!
            Though there was a glitch in the current waveform not sure if it will be a problem.
            Here's a picture from my current probe. It's 10ma per mv...
            Also not sure about ground referencing on this design.
            Here's the new drawing;
              If the frequency gets severely dragged by bias or supply changes, yes it may be a problem. With a better Q you'd most probably miss it.
