Exploring a contraption design for ferrous only detection...
  • Exploring a contraption design for ferrous only detection...
    Hi.
    A very preliminary exploring post, to gather opinions of experienced in electronics, to evaluate if building an odd contraption is worth the try.
    A 3m /10ft long PVC pipe (or longer) of the convenient diameter. Perhaps 10cm/4".
    Inside and along its whole lenght, a plastic or wood strip where circuits and coils will be mounted. This is for removal/inspection ease, can be pulled out and reinserted. The pipe provides a tough protection as it will be carelessly dragged transversally over soil, not rolled.
    Say ten transmitting flattened rectangular coils lined one after the other on the strip, About 4" x 12" each.
    sort of
    A[|=====| |=====| |=====| |=====| |=====| |======| ... |=====|]B
    All being driven simoultaneously in parallel o series -or individually-.
    Ends A and B caps attached to ropes, say end A supplies transmission cabling from the 'dragger' also. Say B supplies also a cable from the 'dragger' with DC power for receivers and signalling.
    Ten more coils for sensing concentric to each for reception. Ten reception/detector circuits with them. Nothing too fancy. Finding shallow bottle caps items is fine.
    Ten LEDs for the sensors. A beep speaker by the towing/person/vehicle when any of the LEDs flashes.
    The point is to cover a very wide path. When a beep is heard, stop and check which led is latched on. That tells which coil sensed something. Dig or drag a powerful magnet to pick item and reset the LEDs to off manually with a pushbutton by say end B.
    Many details to take care of, but, chances it may work ?
    Yes, dragging a loooong powerful magnet would work too. But stay with the contraption.
    I can foresee a ton of problems with this approach. Firstly, to make sure you're covering the whole area, you would need to place the coils close together. Unfortunately this means they will also interfere with each other. Secondly, it sounds from your description that you're planning on using concentric coils, and this type of coil needs to be overlapped between sweeps. If you're not concerned about discrimination, it would be better to adapt a PI to sequentially pulse the coils and reduce the interference problem.
      http://www.schonstedt.com/index.cfm?page=GA-52Cx
