Pulse star game sound solid light circuit edebilirmisiniz help! .. U10 opamp problem with the signal at the output of the original pulse 1 no pun star I'm getting the sound but when I finally use the output of this signal does not occur. Voltmeter u10 opamp No. 1 at the output stage 0 / -5 have different values between logarithmic amplifier as composed essentially where 0-180 degrees phase shift is activated and the original pulse star II tone or pulse ar III sound in this way obtained a sound could have any. Changes must be made on or after u10 problem there, but a suitable circuit threslhold between 0 and -5V output will occur, when I use the original scheme distance loss occurs and what exactly is a technical condition between U10 and U13? Your AƧıklayabilirmis. I can surprise my problem now briefly u10 solid sound-level threshold in order to receive signals, what are your recommendations.
puls star g light help
