what is the best solder to use on PCB boards
  • what is the best solder to use on PCB boards
    Good morning i am just about to start building my new surf pi i used .60 resin cord solder on other jobs i have done works well i have been told that the residue flux can affect the PCB board if you don't clean it all off as i am new to this could some of you chaps that have the experience give me some advice.Regards Kellogs.
    Here's what the experts have to say:
    http://www.circuitnet.com/experts/73284.shtml
      Hi kellogs; the 60/40 rosin core solder cleans well with 91% Isopropyl Alcohol, the kind you use for cleaning cuts and abrasions. It comes in different % ratings so use the stronger for less work. I use a toothbrush and cotton tipped applicator to clean around every solder connection. A side benefit is that you will catch any missed solder joints or notice bad or cold solder joints as you clean the board.
        Hi mate thank you very much for the info it was a great help i have a lot to learn with this hobby.Regards Kellogs
          Hi Chet how have you been i posted a thread a couple of days ago letting you know i was back we have just finished major renos to our house so looking forward to start building my new surf pi thank you for you help again much appreciated.will keep up to date on how i am going you blokes are fantastic.Kindest Regards Kellogs
            Hi kellogs, good to see you back, I look forward to you getting a successful build. I built the Minipulse Mini kit. It works fine on the bench. I am experimenting with different coils and other ideas. Need to add some kind of ground balance circuit before putting it into a box for field testing.
