XP DEUS PROBLEM very strange
  • #31
    I am disappointed from XP company and their products,
    they did not help me to fix the trouble. I am 100% sure my deus problem is the software,
    but they don't help even by some simple instruction. That how Xp react with customers.
    Anyone can help me to fix the problem. The XP said "send back the deus" which is impossible for me to send,
    I never can send it back to france because I will loose it for ever.
    Thanks for helping.
    • #32
      For me the first question would be:
      Is it acceptable enough still working with this detector including using always that earphone-trick or not.
      If yes - I wouldn't bother any longer with this technical and so far unsolvable problem
      if no - there are plenty of other, better, deeper, less expensive etc. detectors available like the lightweight Makro Racer
      with 40cm coil, wireless bluetooth headphone, vibration alert, LED-light, meteorites stones detection etc.
      Pishdari there seems to be no easy help - this is chip-programming and something for experts.
      You may find in special forums answers but I think it's wasting time and work.
      Seen from your described problems I can imagine that its some "mount hardware" problem.
      If the firmware works similar as Linux it may mounts first the headphone-wireless adapter
      and only then it's able to mount or see the coils.
      Perhaps something went wrong with the internal hardware-IDs or its some security issue - I don't know
      what sort of protection-code this detector has inbuilt so it's limited to special registered coils only or not.
      There are no simple solutions, you may find some second hand XP Deus controller device that works with your coils
      or you must look for a complete new or used package to get the full features back. If you still can trust this device...
      And don't forget:
      Try not geting aggressions because of technical devices which don't work as they should - or it could be quite expensive...
      • #33
        The lesson here is, if purchasing a commercial product, buy local whenever possible. It may cost a few bucks more, but well worth it should something go wrong.
