Simple Russian PI detector Pirat
  • #76
    1 meg for my circuit? I saw that other ones using 100k plus 10k.
    Yes i need to use used 1 Watt resistors because i have only 1/4 Watt in every size.
    I tried to use 4 of them together to reach 1 watt but this doesnt seem to work.
    I think i will wait till my russian ic arrives and i will make the radioskot version with the 220 ohm resistor and one pot.
    Im still not sure if its good enough for a poinpointer. I have tried my cable finder tool as pinpointer today and its totally crap, i want something
    stronger.
    • #77
      Nothing arrived until now. But i got a copper clad board, and i made my first self etched PCB.
      It is the version from Hammerhead. Has somebody a schematic from it? its the NE555 +L072 one , small layout.
      I have the problem that i have only one 220 ohm resistor and it seems that i can not use it with this layout but im not sure.
      Almost any Pirat version use this 220 ohm resistor but not this.
      • #78
        22o Ohm is damping resistor. You should be fine with it. It should be matched to your coil. Optimum could be more or less. They just plugged that in as a Starting point .. Ball Park.
        • #79
          Damn , i printed it at the wrong side, and already etched it. lol
          I need a new layout file. Can somebody give me the layout file from this three pictures: http://blog.novaeletronica.com.br/en/detector-de-metal/
          I dont know how to print the pictures in the original size. I have all parts from this layout , its just a bit bigger.
          Or is it the same as the other ones?
          • #80
            Open this i and it will come out to size.Click image for larger version
            • #81
              Do you mean that i should save the file at my Desktop and then right click and print?
              • #82
                Do you have another layout with the same parts which is smaller like the other ones?
                • #83
                  I think what is going on is you have your print set to fill page. Put setting to Print as is. The PCB will come out the correct size.
                  • #84
                    I found a layout from simple pi, looks like it is the same.
                    Need a .lay file if possible. I will try it tomorrow.
                    It's from this link: http://www.thunting.com/smf/pi_desig...t21224.30.html
                    But i dont have an account on this site.
                    • #85
                      Does anyone know where I can buy k157ya2 that can ship to Brazil?
                      (Pay with VISA International or PAYPAL)
                      Thank you.
                      • #86
                        Just build the TL072/71 version.
                        • #87
                          [QUOTE = BKY1337; 231282] Lol
                          Or is it the same as the other ones? [/ QUOTE]
                          My PCB drawing made in February / 2013......
                          The last two videos are mine too.
                          Very poor operation.
                          I find that without original k157ya2, it does not work......
                          It follows files, including PROTEUS ARES if one wants to modify.
                          https://drive.google.com/open?id=0B4...UhfbVVGZEpzWms
                          • #88
                            don't work very well... ...
                            • #89
                              LOL, Drill it and Solder from the top. Ugly but works.
                              • #90
                                Well some thing else is wrong then. Nothing wrong with using the o71 or o72. These are about as simple of a PI circuit as you can get. Not even a Delay line other then one cap.
