I got to power up my SM Pro tonight. I adjusted R 10 to 0 volts on pin 6 of NE5534P then adjusted R2 to 3.3k as the instruction that came with my SM Pro said do. Everything seams to work fine as I had a 4" coil attached. I changed to a 8" coil and my reading at R2 went to 6.2K. Is this normal ? Do you have to adjust R2 to the coil you are using.
Didn't have much time to work with it but the 4" coil would pick up a US penny at 6" . Will try to work with it again maybe tomorrow or Thursday.
