pi metal detector fet driver
  • pi metal detector fet driver
    hi all
    i am sure many will agree when i say stop
    yes stop mounting the driver fet for the metal detector on the main pcb
    this is ohhhh so stupid
    think about a masthead amplifier for a tv antenna system to get max gain
    fet stages hate capacitance so limiting the down pipe too just an rx up pipe
    gives a better cleaner signal scope
    then a more comprehensive folter can be added
    requiring just a timing signal and voltage down also giving a power control via regulation
    so......
    The keep it in the coil Campagne is launched
    forinstance with the terrozo ib bfo coil type detector
    mounting the oscilator in a nice box with a rosin keeping the oscilator componets stable in a poting box makes a very sensative detector indeed
    adding a better shielding using copper .2mm foil instead of aluminium gives better noise reduction and sensativity
    Re: pi metal detector fet driver
    >hi all
    >so......
