Surf PI 1.2 problems
    Originally posted by localbug View Post
    Qiaozhi I'm using PCB board from silverdog
    I have a blank Surf-PI Longboard from Silverdog (marked SURF 1.2 "ApB"), and ICs U4 and U7 are definitely connected to the -5V supply (U6 pin 5). That is ..... as long as you remember to put in the wire link that is located between R8 and U2 on the PCB. If you do not have continuity between U4 pin 7 and U6 pin 5, then you've either not inserted the wire link, or there's a break in the track somewhere
    Note 2 in the datasheet just refers to the conditions under which the tests were carried out. This is not a restriction.
      Why delay configuration failed/didn't work
      4093 NAND gate schmitt trigger
      input1 input2 output
        Are you saying that you've found the fault in your Surf-PI?
          Yes, if I am the only one having this problem.
          No, because I found 4093 wrongly configured on the schematic and PCB.
          4093 truth table
          Positive Positive Negative
          Positive Negative Positive
          Negative Positive Positive
          Negative Negative Positive
            4093 truth table
            There is no fault with the Surf-PI schematic. Many members have successfully built this detector, and the schematic you're referring to is an original from White's Electronics.
            Did you check (as I suggested earlier) that you have +/-5V on IC4 and IC7?
              U4 pin7 -4.7v , pin14 5v
              U7 pin7 -4.7v , pin14 5v
