PCB Tesoro
  • PCB Tesoro
    Hi, everybody!
    Eager to try building Tesoro Eldorado and 'Noname' with notch function.
    Any hints where to get PCBs.
    Lots of thanks in advance.
    Re: PCB Tesoro
    Hi Rudolf
    The unknown 'Noname' with notch filter could be a Tesoro Panther.
    Chris
      Re: PCB Tesoro
      The ,, noname ,, could also be the Tesoro Golden Sabre . It has a notch function also. Kees
        Re: PCB Tesoro
        Hi Kess
        Could be...could be not...A few month ago I saw an old image of the Tesoro Panther. The Panther had a double poti for the notch filter (width & level) and the Gold Sabre has only a single poti for the notch filter. If I can find the image I'll post it.
        Chris
          Re: PCB Tesoro-where are you finding these?
          Hi Folks:
          Can I ask a favor? Where are you finding these circuits and PC boards?Perhaps I missed a post or something, but I've only seen a schematic for a Tesoro Silver, and that one apparently had an error in it... I don't suppose that any of these have been actually built?
          BG
            here the pantera image....& field test
            Pantera Field Test
              If some of us would share what they have collected it might be possible for more of us to start building these units . Just my opinion ! Kees
                Re: PCB Tesoro
                That's it! Corresponds to the cuiquit I ment.
                  No problems with circuits, PCBs hard to find.
                  Rudolf
                    Design your own if you have to . The schematic is the most important part . If you have any make them available to the forum . ( please ! ) Kees
                      Re: PCB Tesoro-where are you finding these?here's one, but I don't know if it works
                      Hi All:
                      Here's a PCB that I found by searching the archives. It was posted by Alan Craik back in December. Massimo has promised to send me a PCB and schematic for his Eldorado that he's built, I'll post that if I can convert it from an Autocad file.
                      Check this circuit carefully, though... according to Marcello on August 18, 2002, the SS circuit is missing a capacitor, and a negative supply point is incorrectly marked as positive.
                      I tried to figure it out myself, but it's makin' my head hurt. I've definately got a lot to learn in the electronic engineering department. I really would like to build one of these, or another tesoro-type detector.
                      Best
                      BG
                        Hi Kees
                        The circuit i mentioned is a .pdf file so i can't upload it. I can mail it to you if necessary.
                        Rudolf
                          Please Rudolf ,if you can mail it I will be comparing it with the schematics I already have . Something is wrong in mine but I am not sure what it is . Kees
                            if you use sprint layout app from abacom
                            it is a cheep app too purchase at only about 40$
                            this gives the ability too overlay a bmp then simply recreate the design on the new board by simply jointing the dots
                            this feature will be automatic in the next version
                            but its very handy for copying a board from a photo and will allow from global resize of all tracks and points
                            to exactly fit the origial
                            has very nice librarys too
                            i hope i helped
                            other than too add
                            i have the schematic for this detector
                            abacom
                              it might be interesting
