What is your opinion about multi freq and single freq
In text bellow
The term "multi-frequency" and MineLabs is a bit confusing, because they actually only run on one frequency at a time (from the research I did). When you first power them on, they search for a clear frequency (one) and then operates on that. They do not process but one at a time. And minelabs loves to set back in the shadows and let this conversation roll on.
You can't choose a frequency,
The display doesn't give you anything about the other 27 frequencies,
If you want to hunt lets say gold, you cannot select the best frequency for that, its chooses the quietest one.
It doesn't even tell which one its selected.
They would have you believe that the detector is constantly scanning the ground with 28 frequencies and then based on what metal it hit it uses the best one for that metal, not so! its running a pre-selected one based on it was the one with the lest interference.
What I don't know for sure is do they have a REAL 28 frequencies to choose from, or are the 28 just harmonic frequencies and the detector actually has a much less number to run on, like 3, 5, maybe 10 Who knows, but one thing for sure Minelabs isn't going to come out and settle this, in the shadows they like all the talk, its keeps the name in the top of the post in forums all over the world.
In text bellow
