Surf PI "problems"
  • Surf PI "problems"
    Hi!
    I've recently finished my second surf PI detector from Silverdog. A few days ago a friend and I went out to test them. The detectors worked perfectly but.. if the detectors are getting to close to each other we both can hear a beeping sound in our headphones. It only stops if one of us switches off the detector so it must be some radio interference going on between them. My questions are:
    Would it help to change the main clock frequency on one of them?
    What's causing the interference?
    DanShield
    Originally posted by DanShield View Post
    Hi!
    DanShield
    Unlike a VLF detector, changing the TX pulse rate on a PI will not reduce the interference. This is because PI detectors use a wideband receiver. The only solution is to stand further apart from each other.
      Ok I see. Thanks anyway Qiaozhi for superfast reply.
        In fact, I have two PI detectors here; one running at 1kHz, and the other at around 5kHz. They both go mental when within 6 feet of each other.
          So it's not just mine detectors, good to hear.
