Iron masking
Kinda answered my own question.
On another forum I found this
"This test peaked my interest and was something fun to do tonight.
used an Australian shilling 925 silver bit smaller than a quarter and a 3" nail
just grabbed what I had set up and a couple swap outs.
Cibola with CSC : Pass
Vaquero with 6 x 8 Detech DD coil : Pass
Outlaw with 7" concentric coil : Fail
Compadre with 5.75" Concentric coil: Fail
Silver Micromax 4" Concentric coil: Fail
F19 10 x 5 Fisher DD coil : Pass
CTX 11 DD coil: Pass
Compadre 7" DD coil: Pass
Silver Micromax 7" DD coil :Pass
Silver Micromax 5.75" Concentric coil: Fail
Outlaw 7" DD coil: Pass"
Seems DD pass and concentrics fail this test but don't understand why
Wilson
But the Wilson does not have a DD coil.
Originally posted by Arthur-Canada View PostBut Wilson does not have a DD coil
I have tested the nail, coin and nail. Where the nails are 2" higher than the coins.
Tested with a IDX with a 10" DD and 8" concentric. The DD wins if I swinging down the nails and the concentric wins if I swing across the nails. So explains the results in the long list.
Originally posted by Koala View PostDon't have a Wilson to test so can't find out what's going on.
Recently i hunted on a roman field, settlement loaded with iron. Most of the coins found there were not deep, very close to the surface. Each year after the tractor plough the field, new targets appear. I have xp deus. Now, there are a lot of settings to adjust, but will not improve much. Who has experience with this, maybe can give some input. Looks like other detectors can see through iron, what is the explanation? Depth is not important, separation is.
On this thread: https://www.geotech1.com/forums/show...613#post213613
#314, #315 i found useful information.
Smaller coil can be a solution. What about frequency, signal amplitude?
Main targets are small silver coins, copper coins.
Originally posted by ionut_mtb View PostRecently i hunted on a roman field, settlement loaded with iron. Most of the coins found there were not deep, very close to the surface. Each year after the tractor plough the field, new targets appear. I have xp deus. Now, there are a lot of settings to adjust, but will not improve much. Who has experience with this, maybe can give some input. Looks like other detectors can see through iron, what is the explanation? Depth is not important, separation is.
recovery speed
separation
lets take separation. Place a large piece of iron on the ground. The place a tiny target next to it. No detector will see through the iron. The First it detected is at half the coil diameter. I have test lots of targets and machines and its always the same. Its always coil dependent
now let's take recovery speed. After seeing iron how long is it before it can detect again. Look on YouTube for Norfolk Wolf machine test. This is machine dependent. A fast recovery doesn't find any more targets, but does mean you can swing faster in iron.
There is no magic machine
There are plenty of "fake" YouTube videos implying a machine is better than any other. As an example there's a video say its the only detector that can see through iron. They place a coin on the ground and cover it with nails. Then swing across the nails. I have tried this for myself and any machine will pass this test. Swing down the nails it fails which isnt shown in the video.
There's loads like this. You can fudge the Monte nail test by changing the settings but would be unusable in a real field and so on.
Concentric and DD preform differently but one isnt better than the other.
First to mention that i have also lot of such sites here.
When i step on such site, as you described; first i do proper ground balancing, manually, by bobbing a coil and adjusting GB until is balanced well.
Next i switch to Deus Fast preset. Rise sensitivity to 94. Iron volume 3-4. Disc at 4.
Reactivity 2.5-3. But MOST IMPORTANT is silencer. I rise it to 3 and often to 4. In case i don't want to hear iron trash.
In case i want to hear all the signals; silencer -1 to 0.
And than i do the fast but short swinging over each target. Crossing and swinging.
You have to listen carefully the response.
No matter the detector; most of the job is done by "human factor" and experience.
Such sites are pretty tricky but in my book those are most desirable type of sites and most interesting to search.
XP Deus is good and can handle such sites very well.
But only if you add the "human factor".
Here in the eastern USA I detect old farms. Lots of iron trash but also many good targets mixed in.
It is the 'human factor' that finds the good targets.
Originally posted by ivconic View PostI will tell you how i search with the Deus under such conditions.
Separation in iron can be divided into 3 groups:
Group 1 is "Signal averaging" - nail up and coin 2-3 down - this is well shown in the video .. with Wilson ..
2nd group 2D shallow separation - a classic and very good example is .. "Monte Performance Nailboard Test" ...
3. The group is a 3D deep separation ... and not every detector has such a * 3D predisposition.
I am not quite sure just what they do to IRON MASK. I thought it was more or less an method of filtering out a particular frequency, either with an unique circuit or a notch like circuit, to eliminate an particular resonant frequency. In other words they are not really masking the iron, but in circuits actually discriminating the iron they want to mask OUT???
Maybe one or both of the moderators can fill us in with this explanation???
Melbeta
El Nino has the best response. Let's look closer...
"Recovery Speed" and "Separation" are really talking about the same thing, namely how fast a detector can detect a target, respond to it, and get reset for the next target. This can be 2 desired targets (say, 2 silver coins) or it can be a desired target next to a discriminated target like a nail. With many detectors the disc'd target has its audio blanked out so if the detector does not respond fast enough the silent nail can completely mask out the silver coin. I call this "recovery masking." If you get a good signal swinging the coil in one direction but no signal in the other direction it is likely because of this scenario.
I like to test recovery speed by placing a US silver quarter between (2) 16p nails and, while sweeping the coil at 1 m/s, decrease the spacing between the nails and the coin until the detector no longer issues 3 distinct responses. An average detector will give 3 responses down to 4"/10cm or so. An exceptional detector can get down below 2"/5cm. Any given detector will always perform better at this with a smaller coil. This test is what El Nino calls "2D shallow separation" because all targets are in the same plane, like Monte's nail board.
Once you get below the distance where the detector can give 3 distinct responses you begin to see a combined response. This is El Nino's "Signal averaging" case. If a nail normally has an ID of 20 and a silver coin is normally 85, then a silver coin and a nail together might ID at, say, 50. This is also a form of masking but it has nothing to do with recovery speed; no detector can recover fast enough to separate 2 targets exactly co-located. Let's call this "average masking."
El Nino's 3rd case -- "3D separation" -- is when you have, say, a shallow nail and a deep silver coin. Or vice versa. This can alter the recovery speed because, for example, a strong nail may more easily mask a deep/weak coin, so you need more distance between them in order to get the coin response. Also affects average masking as a strong nail and weak coin will have an average that is closer to the nail.
