Potentiometers
    look attentionally that he tells
    In the production of various prototypes of electronic devices in plastic cases there is a need for shielding these devices, i.e. protecting the devices from external fields. It is easy to cope with this task using the Emi35 preparation, which represents a thermoplastic rubber containing micro particles of copper, providing a high electrical conductivity of the coating. This coating forms a reliable and unnoticeable conductive shield on the surfaces made of plastic. Current conducting shield blocks "noise" electromagnetic radiation of electrical and electronic devices (suppresses electromagnetic noise), as well as protects extra sensitive devices from electromagnetic noise of other devices. Using the preparation is very simple ... You stir the can until the metallic ball inside the can is released and then spray the preparation from the distance of 10 cm approximately onto the surface that is to be shielded, with overlapping of the coated layer of 50%. Drying time of the layer at indoor temperature: 30 min before the adhesion effect disappears, and 24 hours until the complete drying. Thanks to the screen we got, the noise level can be reduced to 60 dB. This facilitates maintenance and servicing of office equipment, measuring instruments, installation and maintenance works, as well as the adjustment of the precision equipment. So when you use the EMI aerosol cans for relatively small amount of work, you can achieve great results.
      This get deeper,,Thanks KT315
